Stuck in first gear
Steve
02-03-2001 20:26:48
This afternoon during snow removal, my WD slid partly off the road. The tractor was "tweaked" and when I shifted into reverse, the shifter went into the neutral slot but the transmission stayed in first. Now I can't get it out of first. I know nothing about transmissions. Any help would be greatly appreciated.
Brian G
02-04-2001 07:22:44
 Re: Stuck in first gear in reply to Steve, 02-03-2001 20:26:48
And..... make sure that little pin in the side of the shift tower that keeps the lever from turning does not drop down into the tranny.
Aaron
02-03-2001 21:01:21
It's not a huge thing to fix. First, slide the shift boot up so you can see and get into the shift tower. Get a couple of flat balde screwdrivers. use them to remove the snap ring holding the shift lever in. When you get hat out, take the shift lever out and use a long screwdriver to feel around and pop first back into the neutral position. Remember, "over and up" on the hand end of the shift lever is actually "across and down", aka:backwards. You can see down the hole to tell where you need to do it. I did my first one in the dark in the rain, so if you have daylight and dry, you should be just fine. Make sure it all gets put back together opposite of removal and try to keep the dirt to a minimum.
Aaron
