WC/WD Steering Spindle Shaft Bearing
Ric
02-02-2001 17:12:29
Can not find a new bearing anywhere. It is the tapered roller bearing that supports the weight of the front of the tractor. Wheel bearings were no problem.
steve
02-03-2001 18:45:07
 Re: WC/WD Steering Spindle Shaft Bearing in reply to Ric, 02-02-2001 17:12:29
I dont know anything about the WD tractor, but any bearing used in tractors can be purchased from one of the big bearing houses. I order a lot of bearings from "Motion Industries" also known as "Berry Bearing" . "Bearing Headquarters" is another good place. You would have to take the bearing with you and they can match it up by size. These bearing houses are in all big cities, look in the phone book. I have the number for Quincy Illinois if you are close to here. If the bearing race has a number on it, you could order over the phone.
steve
02-03-2001 18:44:40
chris johnson
07-18-2002 14:40:06
 Re: Re: WC/WD Steering Spindle Shaft Bearing in reply to steve, 02-03-2001 18:44:40
1949 ALLIS C, WOULD YOU PLEASE SEND ME A TEL.# NEED A BEARING
acd17toy
02-03-2001 18:38:47
if you have the old bearing or enough of it to get numbers off of it take it to a place that specializes in replacement bearings i found one that way for my sons wd a few years ago
