CA Puller
R Datkuliak
02-01-2001 14:32:46
I have a 55 CA that I want to pull. I would like to put a D-14 engine in it. Does anyone know if the block will bolt to the CA torque tube? Any help appricated
FRANK
02-01-2001 16:24:52
 Re: CA Puller in reply to R Datkuliak, 02-01-2001 14:32:46
R. THE D14 ENGINE WILL BOLT RIGHT IN,BUT THE BLOCK
HAS A HYD.PUMP MOUNT BELOW THE DISTRIBUTOR AND THE MANIFOLD BOLT PATTERN IS DIFFERENT. I WOULD READ THE RULES FOR THE CLUB THAT YOU
PLAN ON PULLING WITH,THE "CA" MOTOR CAN BE BUILT
TO OVER 200 CI WITHOUT MUCH TROUBLE.
Ron
02-01-2001 15:44:55
Yes it will bolt right in front and back. If you realey want to go pulling put a W201 in it! I have a 52 model B that is set up that way! Ron
