D-17 diesel
Robert Dewilde
01-28-2001 07:14:52
Hey, just purchased a D17 diesel series 2,Has anyone out there changed the hydraulics over to the series 4 style. How much trouble is it? what's involved? Appreciate any info you can give me! Robert
Darrell Jr (MN)
01-29-2001 18:41:18
 Re: D-17 diesel in reply to Robert Dewilde, 01-28-2001 07:14:52
Robert, from what I have heard, unless you have the rear half of a series IV, you can't put the series IV pump and valves on an earlier model and make it work like a series IV. That is what I can remember from past posts,and I could be wrong. good luck, Darrell Jr (MN)
lonn
01-29-2001 16:03:04
A similar set up to the Series IV was actually an option on the early D-17's w/triple set of remotes and a separate resevior. Had 15 gpm at 1500 psi. In hindsight AC made a mistake when they didn't make that standard equipment. I have a 1960 sales brochure showing this option. Sure would like to set mine up that way.
John(VA)
01-29-2001 07:31:30
Robert, I think that doing this will be a chore. But I am not sure. It seems to me that I have read on the unoffical allis page that the pumps are different and the pump for the series 4 tractors is located up at where the belt pulley is meant to be. I think that the pumps on the series 2 tractors are somewhere in under the seat.
Well I am surely no expert, but maybe this will get you started. Hey you have a really good tractor. I have one. I just take it for what it is. We pull a Gehl round baler with our series 2. My dad put a, well what I would call a Hydraulic valve on it. So I can plug in a line that will push and a line that will return. The only problem is that it doesnt have pressure on the return, but the gate on the roller is heavy enough to shut its self down. Good luck!
