Oil pump 52 CA
Larry
01-27-2001 12:09:04
Is there a oil pump rebuild kit available for my 52 CA and who sells it. I've tried priming pump by squirting oil in tube that goes to pump,it will push that oil out but does not seem to pump oil up from sump,any ideas HELP!!!!! This tractor sat for three years,runs good but no oil pressure!
Ron
01-27-2001 12:24:44
 Re: Oil pump 52 CA in reply to Larry, 01-27-2001 12:09:04
Time to pull the oil pan and check the pick up tube and screen. Ron
Dick L
01-27-2001 12:24:18
If you take a look at my post at the bottom of this page or when I post this it might go to the top of page 2. The ball could have pits in it or just crud. I bought a 5/16 steel ball at ACE hardware to replace the one in the picture. You might have to resurface the cover as well. The vanes could be stuck also.
You will need a thin gasket under the cover or it will bypass oil and not build pressure.
I dought that you will need any parts that you can not buy in the hardware other than a gasket.
Larry
01-27-2001 14:32:28
 Re: Re: Oil pump 52 CA in reply to Dick L, 01-27-2001 12:24:18
Thanks Dick I was afraid I would have to do that, I know the pump itself is not a project,but separating the tractor is,just have to do what you have to do! Thanks Larry
