Carb.
Larry
01-22-2001 16:26:08
I have a 1952 Allis Chalmers CA,that has a Marvel Schebler carb. does the tsx 154 carb come with this tractor, I ordered a rebuild kit from Walt's Tractors ,item#uao611 ,kit # bk 310,which is supposed to be for this CA tractor and after receiving kit it shows that that kit fits tsx 670,701,and 815 carbs,problem is everything will work except the throttle shaft,its roughly 3 1/2 inches long where as mine is only 2 1/2 inches,whats the deal! Thanks
Phil Auten (TX)
01-22-2001 19:11:37
 Re: carb. in reply to Larry , 01-22-2001 16:26:08
Larry,
According to my I&T manual, the CA used a Zenith 161J7, the same as on the B, C and RC. There is no Marvel-Schebler carb listed for these models. It's possible someone swapped the carb from a different tractor to repair it sometime in the past. This leaves you with two options, find a kit for the existing carb or find a correct replacement Zenith carb. Hope this helps, Phil
Larry
01-23-2001 04:35:17
 Re: Re: carb. in reply to Phil Auten (TX), 01-22-2001 19:11:37
Thanks ,Phil but my AC manual from binder books shows both carbs for the CA and I have a friend that has a marvel schebler carb on his 56 CA?????
