BE CE Engine Number w/ K
Dale
01-21-2001 16:12:07
Just drug in two AC B's to work on. One B has a BE engine # with K at the end. The other B has a CE engine # with a K. My other CA & C's have CE engines with a G at the end. I'm guessing that K means distillate and G means gas. Is there anything special that I need to know before rebuilding them. One is frozen and the other is not. Any help would be appreciated!
Heerb Brady
01-22-2001 14:49:48
 Re: BE CE Engine Number w/ K in reply to Dale, 01-21-2001 16:12:07
The compression ratio is differnt on them and the horse power rating is slightly less on the k engine but they both will run fine on gas. Also if the k model has the original exhaust manifold it will be different with a tin housing mounted on it so the manifold will run hotter for the low distalate fuel.
Korry
08-09-2001 12:41:29
 Re: Re: BE CE Engine Number w/ K in reply to Heerb Brady, 01-22-2001 14:49:48
Hellllp!!!
I'm looking for information, on a "B" Allis Chalmers Tractor....What horse power are they, and will they handle a John Deere, "24T" small, square baler??? Thanks, :) Korry
Dale
01-22-2001 18:31:37
Thanks Herb and Dick for the info! There's no tin on the manifold, but there are a few more ports than on other manifolds that I've seen. I got her unfroze, will know more later. Thanks again!
Dick L
01-21-2001 17:41:01
Nope, they be the same on the inside, except for piston size maybe.
