AC- C fluids?
'Bandit'
01-21-2001 12:21:09
what kind of oil should i use in the PTO/ hydraulic unit on a model C? also where do you add the fluid for the PTO? i found where you drain it, but now i can't figure where to put the fluid back in. Thanks.
Tom
01-21-2001 14:59:30
 Re: AC- C fluids? in reply to 'Bandit', 01-21-2001 12:21:09
Add oil through the transmission filler plug, on the side of the transmission. the transmission, rear end, and hydraulic system all use the same oil. A 20 weight non detergent oil is what the manuals recomend for the B and C.
