D-17 thermostat
Dave W.
01-20-2001 16:56:43
Still haven't found the right thermostat.The closest one was from NAPA, a 2 pcs. but still floats around inside housing. The original was 3 pcs.(very rusted when I took housing apart). Anyone have any ideas or suggestions?????
Steve
01-22-2001 19:00:15
 Re: D-17 thermostat in reply to Dave W., 01-20-2001 16:56:43
I put a 350 chevy thermostat in my D17 diesel and it fit perfectly and has worked fine
lee (MN)
01-21-2001 07:51:49
did you try agco for an oem thermostat, I went through a 17 engine last summer that had a 2 piece thermostat and replaced it with a normal 1 piece unit from car quest and do not recall any problem finding it. is it possible someone has modified the thermostat hsg.? maybe you need a new hsg. good luck.
