Allis chalmers c or ca timing points
dennis bush
01-19-2001 14:48:17
just got tractor not even sure if it is c or ca not running but not stuck. wide front. got rear wheeel bearing out. i think mag is bad need info on timing point gap etc. how do i find out what year and model it is thanks a lot dennis bush grandville tn
Phil Auten (TX)
01-19-2001 16:52:54
 Re: allis chalmers c or ca timing points in reply to dennis bush, 01-19-2001 14:48:17
Dennis,
Look right in front of the shift lever for the cast in TRACTOR NO. Right to the rear of that is the S/N and that starts with the model (C for a C and CA for a CA). Also, the CA should be a 4-speed vs. a 3-speed for a C. Either way, they're fun tractors!
Phil
Dick L
01-19-2001 15:45:30
third party image
This is a C. I posted a magneto picture below, points are set at.020. You can find the timing mark on the flywheel looking through the round inspection hole on the left side. Like most engines, start to time at top dead center on compression stroke of number one cylinder.
Dick L
01-19-2001 15:23:30
third party image
This is a CA. Notice the bosses in the bottom of the front grill, also the two bosses in the center of the torque tube, and then the spin out rear rims. The C does not have these three things.
There are other differances but you can see these in the picture.
Ron
01-19-2001 15:37:55
 Re: Re: allis chalmers c or ca timing points in reply to Dick L, 01-19-2001 15:23:30
Dick L That is a real nice little CA you have there,nice pic.too Ron
Dick L
01-19-2001 15:47:16
 Re: Re: Re: allis chalmers c or ca timing points in reply to Ron, 01-19-2001 15:37:55
Thanks.
