WC with WD-45 Crank
Ric
01-18-2001 16:52:34
I am building a WC engine and want the 4.5" stroke. I bought a new WD-45 crank and the journals are too big and the timing gear will not fit. Are there 2 types of WD-45 (gasoline) cranks? One that will fit a D17 motor and the other that will fit a WC / WD motor??
Ted Buisker
01-20-2001 08:11:44
 Re: WC with WD-45 Crank in reply to Ric, 01-18-2001 16:52:34
Some of the very early WC's had a smaller journal crankshaft in them. The Rod journals were smaller, I don't know about the mains. If the casting number on your crank is 226535 you DO have a 45 crank, and it should fit.
Rick
01-18-2001 19:53:44
What's the casting no. on the crank?
unstyledWC
01-18-2001 19:53:02
You have a d sereies crank would be my guess.
Aaron
01-18-2001 17:34:41
My guess is you have a crank out of a D series. The WD45 crank should fit perfectly.
Aaron
