C engine needed in Michigan
Dan
01-17-2001 10:25:59
I have a friend that is looking for a good running C engine for his tractor. His has a large crack in the block. It must be located in Michigan because of travel distance.
Tom
01-17-2001 18:08:49
 Re: C engine needed in Michigan in reply to Dan, 01-17-2001 10:25:59
Where is the crack? Why not try and fix it before buying a new engine or block? JB weld or actual welding could fix it maybe. Using nickle rod, welding only a very little at a time, and peening the welds as they cool could do it. Or just grinding out the crack and filling with JB weld. If you are planning on another block there is nothing to loose by trying to fix this one.
