WD crank holders
Dan
01-16-2001 14:29:45
Anybody have a picture of right fender of WD that shows which fender bolts hold the crank holders?
Dave Kolbenschlag
01-19-2001 14:06:03
 Re: WD crank holders in reply to Dan, 01-16-2001 14:29:45
I don't have a clear photo but can tell you where it mounts. The front (closed) bracket mounts on the front lowest bolt (not the bolt going into the axle). The rear (open bracket) mounts on the lowest back bolt. Handle sits in the closed bracket, other end rests in open bracket. If, for some reason) you need a photo I can take one.
Dave
Dan
01-19-2001 20:39:54
 Re: Re: WD crank holders in reply to Dave Kolbenschlag, 01-19-2001 14:06:03
Thanks a lot, Dave. Description is clear and I appreciate.
