WC engine question
BamaDee
01-16-2001 12:49:54
I have cooling water getting into #3 c ylinder,after pulling the head,I found a possible head gasket failure between #2&3 cylinders.How can I check the wet sleeves for cracks before I put a new head gasket on and possibly not fix the problem? I am trying not to pull any of the wet sleeves if possible. Would a cracked sleeve be visable to and old retired umpire? TNX --DEE
Phil Auten (TX)
01-18-2001 06:14:25
 Re: WC engine question in reply to BamaDee, 01-16-2001 12:49:54
Dee,
Better have the head checked for cracks too. If water gets into a cylinder of a tractor at operating temp it can crack the head in the combustion chamber area. Had that happen to me on one of mine a few years back. Kinda expensive, had to buy a head and then got it redone, cost me about $275 total plus gaskets.
Good luck,
Phil
D-17 Dave
01-16-2001 19:33:41
A crack bad enough to leak like this should leave a rust trail which would certainly be visable. Probably the head gasket.
