AC B HALF SHAFT
NIGEL B
01-15-2001 16:35:57
GOT A AC B THAT HAS A OIL(GREASE?)LEEK FROM THE HALF SHAFT BEARING ,TOOK OF REAR WHEEL,END BUNG FROM HOUSEING TAKEN OUT BOLT+WASHERS, THEN THE BOTTOM COVER TO EXPOSE REDUCTION GEAR, NOTISED THERE IS A LOCKING NUT ON SHAFT,THEN LOOSEND IT UP , BUT SHAFT IS STILL A SOLID FIT, HAS ANY ONE ENY EXPERIENCE ON REMMOVEL OF SHAFT & IS THE BEARING A SEALED UNIT ANY WAY?? REGARDS NIGEL B
Tseifert
01-15-2001 17:36:49
 Re: AC B HALF SHAFT in reply to NIGEL B, 01-15-2001 16:35:57
On the B the outside stub axel has an oil seal that can be replaced with out removing the axel or nut. Remove the cast wheel from the splined axel with wheel pullers. The seal can be removed with a screwdriver or sharp pick or object.
Good luck
ted
Dick L
01-15-2001 18:55:33
 Re: Re: AC B HALF SHAFT in reply to Tseifert, 01-15-2001 17:36:49
Like Tseifert stated you wouldn't have to take the axle out to change the seal. To answer your questions, no they are not seaked bearings, and the bearing behind the inside cap, where you removed the washers and shims, is pressed onto the axle and the axle would have to be pressed out as you unscrewed the nut inside the casting.
nigel b reply
01-16-2001 09:30:38
 Re: Re: Re: AC B HALF SHAFT in reply to Dick L, 01-15-2001 18:55:33
THANKS FOR THE HELP NIGEL B wear can i get a new seal from
Ron
01-16-2001 23:53:01
 Re: Re: Re: Re: AC B HALF SHAFT in reply to nigel b reply, 01-16-2001 09:30:38
Here you go National 415001 weelseal bull pinion seal national 450456
Ted Seifert Austinburg OH
01-16-2001 18:45:13
Remove the seal take it to a bearings place like Bearings Inc, Bearings Distributors or your AGCO dealer.
NIGEL B UPDATE
01-17-2001 09:34:17
 Re: Re: Re: Re: Re: AC B HALF SHAFT in reply to Ted Seifert Austinburg OH, 01-16-2001 18:45:13
THANKS EVERY ONE, THE SEAL LOOKS A BIT OF A SOD TO GET OUT WHATS THE BEST WAY? ALSO JUST TO LET YOU KNOW I AM IN THE UK AND WE HAVE NO AGCO DEALERS AS SUCH ,THE NEAREST EQIVELANT IS MASSEY FERGISON WHICH YOU THOURGHT WOULD DO THE JOB ,BUT NO WHEN THAY SPOKE TO AGCO FOR ME THAY SAID THAY WOULD NOT DEAL WITH THEM, ONLY ME DIRECT AND IL HAVE TO IMPORT IT MY SELF ,FAIR ENOUGH BUT I WOULD HAVE THOURGHT AGCO WOULD SAPORT EACH OTHER IN THE GROUP? REGARDS NIGEL B
J.L.
01-17-2001 22:43:18
 Re: Re: Re: Re: Re: Re: AC B HALF SHAFT in reply to NIGEL B UPDATE, 01-17-2001 09:34:17
Nigel; You should able to obtain the seals you need from you're local Auto parts supplier. The seal numbers you need are as follows, Wheel seals a National [U.S.] 415001, Bull Pinion seal, again National, number450456. If they don't carry National, They should have an interchange manual to find a direct cross match in another maker.
