AC B water pump shaft and lubricant
Tim B.
01-13-2001 18:34:13
I'm new to working on my 1940 AC B - the shaft that turns the water pump and fan is a bit sloppy - is there any way to tighten this, or just let it go? (I'm not even sure how it can be taken apart) Also, how is this shaft lubricated properly?
cap
01-17-2001 19:03:38
 Re: AC B water pump shaft and lubricant in reply to Tim B., 01-13-2001 18:34:13
Biggest prob I had was pulley groove too wide for belt;fan wouldn't turn when running,had to pull radiator, remove fan and pulley. The center of pulley area was full of old rubber preventing any adjustment, I sprayed solvent and finally scraped outenuff gook to get the two pulley pieces free, reinstalled and works great even w/old fanbelt. Not too bad, really. Good wrenching to you.
Phil Auten (TX)
01-13-2001 19:57:46
Tim,
Sounds like it's time to replace the bearing and probably the seal in your water pump.
Phil
Dick L
01-13-2001 19:22:09
third party image
No adjustment and no place to lube.
ed
01-14-2001 21:27:58
 Re: Re: AC B water pump shaft and lubricant in reply to Dick L, 01-13-2001 19:22:09
I've seen International units that had a screw hole.The screw was to be taken out and the lube was shot in every day or so. Wonder why allis did't do that. I have a Allis b and as far as I see there isn't any place to lube ether. Ed
Dick L
01-15-2001 04:48:50
 Re: Re: Re: AC B water pump shaft and lubricant in reply to ed, 01-14-2001 21:27:58
They use sealed bearings. Hard to lube a sealed bearing without breaking the seal.
