CA Running
Larry
01-13-2001 15:44:22
I got my CA running today,runs great for about a half a minute then dies ,let it set, start back up does same thing! Is this a fuel problem?Also choke has to be in or it will not run at all!!!
steve
01-14-2001 05:48:39
 Re: CA Running in reply to Larry, 01-13-2001 15:44:22
Fuel is the probably cause. I note, i worked on a 8N last year that did the same thing after a carburetor overhaul. The choke had to be in and the throttle wide open. I found the two rods on the carburetor switched, the choke was actually the throttle butterfly. Dont know if this can happen on the CA, but linkage could be something to double check.
c tucker
01-13-2001 20:44:56
Take the fuel line off at the carb.turn the gas on. You should have a full stream coming out of the line.If not try blowing compressed air backwards through the line.
