Wiring on a ca
bill
01-11-2001 18:20:43
I reworked my generator to 12 volt, neg. ground. In rewiring do I change the connections on the ampmeter? The positive and the neg. connections are my problem. In rewiring I will be going from the battery to the starter, starter to the amp gauge and from the amp gauge to the battery connection of the voltage regulator. Then I'll jump off the amp gauge to the key switch for the coil connection. So, I need to know what to do with the + and - on the amp gauge!
Ted Seifert Austinburg OH
01-11-2001 19:23:26
 Re: wiring on a ca in reply to bill, 01-11-2001 18:20:43
Yes, exchange the wires on the amp meter when you change from positive ground (standard) to negative ground. If you are also changing from 6 volt to 12 , be sure that you put a resistor in series with the coil, otherwise you will burn the points. Good luck.
ted
