Governor speed
Chuck
01-11-2001 16:39:50
My WD-45 has a governor speed of about 1200 rpm's, no load. The manual I'm refering to lists a high idle of 1677 to 1722 rpm's, and a full load governor speed of 1400 rpm's. How can the governed speed be adjusted, or am I just wishing for more rpm's?
Advice needed,
Chuck
Eversgerd
10-01-2006 10:14:06
 Re: Governor speed in reply to Chuck, 01-11-2001 16:39:50
Need to know same thing on d17 tractor need a schamatic on the Governor
Rick
01-14-2001 11:02:38
Follow the throttle shaft to the rear of the engine. You will find a rod that is adjusted by loosening a set screw and changing the length of that rod. Change the length about 1/2 inch and check rpm. If my memory serves correct, shorten the rod, but if that takes rpm lower move it the other way.
