D17 oil type
steve
01-10-2001 20:17:55
Doing service on a friends D17- 1963. I dont have a book and trying to change all oils. What are the two in front of seat? One is screws in and has a dipstick attached, the other pushes on. Looks like transmission and PTO (bevel gear box?) Also what type of oil in these. Both smell like gear lube. Can i use something like 30 wt engine oil in everything, except axle and be same as engine?
Ryan
01-12-2001 06:20:23
 Re: D17 oil type in reply to steve, 01-10-2001 20:17:55
The oils are not all the same.
sitting on seat they are as follow.
Screw with dipstick is for power director clutch - hand clutch on right side. I believe this can be replaced with updated hy-trans oil
Knob Dipstick between legs is tranny oil Also updated with hy-trans oil.
Knob Dipstick on right side of engine that between two wheels is hydraulic oil. updated with hy-trans oil
Dipstick on lower portion of motor is motor oil. . .I use 10-40 year round .. .but mine has had multi-viscosity oil for over 30 years. If you don't know, use a straight weight, non-detergent oil.
Plug behind radiator is power steering fluid. .WFE is 85wt, NF is 135wt
Rear gear drop chamber oil is 85wt I believe.
These are for my 58 d-17, so your layout may be a little different. Check out the link below, go to discussion forum.
steve
01-12-2001 17:39:44
 Re: Re: D17 oil type in reply to Ryan, 01-12-2001 06:20:23
thanks guys. I did not know which cavity was which. I was thinking of using a 10-30 in both like the engine, or a hydraulic type oil. This helps me a bunch.
Ike
01-12-2001 06:13:13
I have a 1965-Series IV D17 and the owners manual specifies the following:
For the power director clutch and hydraulic system which is the fill port on the left side (while sitting in the operators seat)use "automatic transmission oil SAE Type A". The modern equivalent is Dexron/Mercon III which is available at any auto or auto discount store. When I bought my tractor earlier this year the previous owner was using what appeared to be a 30 weight engine oil which would probably work ok. I elected to follow the AC operator's manual recommendations.
For the transmission (the fill port on the right hand side while seated in the operator's seat) and the final drives the manual recommends SAE 80 EP Oil.
If your friend's tractor has power steering the manual recommends DExron/Mercon III.
I hope this helps.
Ike
