J.L.
01-18-2001 23:15:51
Re: LOVE MY C!! in reply to Gwen Cox, 01-10-2001 15:51:21
Gwen; If properly maintained, you're C should last a life time "+". Most already have. As for trouble spots, they are few. The steering can become loose,easy to correct. The starter drive will sometimes go bad and eat up the ring gear on the fly wheel, not so easy to fix. Listen to the starter at each start-up. If it fails to engage it makes a grinding noise. Check drive and ring gear at once. Run a good motor oil, I use 15-40 Rottella T. Change oil and filter every spring, more often if the tractor is worked hard. I also suggest draining and refilling the transmission at the same intervals,80-90 gear oil if you DON'T have a hydralic pump, Mystic or Philips tractor Hy-Trans, [Hydralic-Transmission], oil if you DO. Final drive cases use 80-90 gear oil, same drill, every spring. Also use 80-90 in the steering gear case. Have fun with you're "C", one caution, as you probably have been told, avoid very sharp turns, and running across hill sides and ditches, as row crop tractors are easier to roll over in these situations, than their wide front cousins.
