TRC
JAKE
01-08-2001 15:06:52
I HAVE 2 AC TRACTORS IM NOT SURE THE SER. SO HERE ARE SOME. 1020,2847Z284, THESE WERE UNDER THE SEAT.
THE OTHER IS A B. HERE SOME MORE #S 204645,200964,THESE WERE ONTHE SIDE OF CRANK CASE.
IF ANY OF THIS IS CORRECT I WOULD APPRICIATE IT IF YOU COULD TELL ME THE YEARS AND ANYTHING ELSE. IF NOT MAYBE YOU CAN TELL ME WERE THE SER# ARE. THANKS ALOT
ed
01-08-2001 15:55:00
 Re: TRC in reply to JAKE, 01-08-2001 15:06:52
The location of the ser# on the B is right in front of the shifter. The # should start with a B if it is a B if not ether a C or I think the CA. Try there and then try again. As to the other one also try the same place and if not the a better discription of the tractor would help narrow it down just a bit. ed
