Wd-45 transmisson
Ron
01-06-2001 17:58:12
How much oil does the transmisson hold and where
do you check it? Also does the transmisson supply the oil for the PTO ?
Brian G.
01-07-2001 18:28:24
 Re: wd-45 transmisson in reply to Ron, 01-06-2001 17:58:12
Like "Sandy" says there are 2 Filler plugs. There are 3 drain plugs: 1.Differential 2.Transmission 3. PTO housing The whole thing holds 17 Qts. The Original manuals call for 80EP, but 80/90 or 90 is what is available today I think.
tom
01-08-2001 14:57:16
 Re: Re: wd-45 transmisson in reply to Brian G., 01-07-2001 18:28:24
Isn't there another plug in the sheetmetal plate on the bottom of the transmission. One on the pto, one above it , one on the differential, and anotheron the transmission.
Sandy Lake Implement
01-07-2001 12:06:57
Not sure of qty. Am at home now-info at store.
2 pipe plugs with square heads on left side of
trans, rear one larger than front one. Fill to
bottom of threads with 90 wt.This is oil supply
for all but hyd & wheel final drives.
