Help needed to Remove Steering wheel
Herb
01-06-2001 15:36:11
I tearing down my AC-b and need to remove the
tool box , but it appears that I need to remove
the steering wheel to do so.
I've removed the acorn nut, but the wheel doesn't
budge. Does it screw off, or what?
Herb
01-10-2001 04:22:40
 Re: Help needed to Remove Steering wheel in reply to Herb, 01-06-2001 15:36:11
The Gear puller pulled is off as smooth as silk.
Didn't need the heat. Just goes to prove "Use the right tool for the job!"
Dick L
01-06-2001 19:24:08
It has a tapered fit with a key. I give the stearing wheel hub some heat and rap it good a few times from the bottom and it pops off. If it dont come off in the first few hits, get a bigger hammer and use more heat.
Marty
01-07-2001 17:19:32
 Re: Re: Help needed to Remove Steering wheel in reply to Dick L, 01-06-2001 19:24:08
I had a really hard time getting the wheel off my C, tried heat, hammer, etc. The fix was to get a 2 jaw puller, and put tension on it, then smack the end of the puller sharply to break the taper loose. This should work for you.
Good Luck,
Marty
