Allis Chalmers 3 point hitch question/clarification
Chris Heiden
01-03-2001 17:36:31
I have a 1960 D14. Since I am new to the tractor world, will the 3 point hitch system on an Allis Chalmers tractor (D14 in my case) hinder me from using Category 1 three point hitch attachments? Is this because of the snap coupler that is underneath? Just a little confusion
Thanks,
Chris Heiden
James
01-05-2001 19:54:35
 Re: Allis Chalmers 3 point hitch question/clarification in reply to Chris Heiden, 01-03-2001 17:36:31
Yes, it is a completely different setup. Although you can purchase a 3-point hitch conversion kit for your D-14. This package allows you to use your catagorie 1 equipment.
Chris Heiden
01-04-2001 08:41:08
 Re: Re: Allis Chalmers 3 point hitch question/clarification in reply to Ryan, 01-04-2001 06:03:27
Ryan, Your picture did not show up.
Thanks,
Chris Heiden
Lazyhorse
01-04-2001 04:18:20
Do you have a 3 point conversion on your snap coupler type setup? if so you can use standard 3 point equipment. Some people confuse the Allis snap couple setup with true 3 point. In the snap couple setup you have a long bar from the implement that snaps into the lower coupler where your drawbar is, and 2 rods that connect to your lift arms. In true 3 point the setup is reversed in you have 1 top link on the upper part of the implement, and 2 arms which raise and lower, that connect to the lower part of the implement. Hope this description helps.
Chris Heiden
01-06-2001 06:09:40
 Re: Re: Allis Chalmers 3 point hitch question/clarification in reply to Lazyhorse, 01-04-2001 04:18:20
Nope. I have the Allis Chalmers snap couple setup. I found out I have to purchase a conversion kit.
Thanks a lot
