'C' steering parts/problems
mark dingbaum
01-03-2001 08:25:35
Hi, great forum here...
I've torn down my '42 C for a rebuild and repaint and have found a few problems I'd like to fix...
The steering sector has been 'fixed' before and has had the three teeth welded up and ground down to somewhat resemble the original shape of the teeth. Worm is fine, case has one bolt/stud welded up (the one with the cam for adjustment).
Anyone have a good sector shaft (splined shaft with three teeth to interface to the worm)? Or even the whole sector assembly?
Also, the front spindle tower has plenty of wear at the top, both in shaft and casting. I'm having a local welding shop build up the shaft and install a bushing in the top of the casting. My gear at the top of the spindle has three broken teeth. Anyone have a spare gear they'd like to part with?
Doug McDonald
08-20-2003 17:13:21
 Re: 'C' steering parts/problems in reply to mark dingbaum, 01-03-2001 08:25:35
Help.Have no luck in locating a steering box for 1069 NH stackwagon Serial #1417.Can anyone help.
Jeff
01-04-2001 20:16:32
May be able to help. Have "Gemmer Steering Assembly" for "C".
