How do you jump start a 6 volt postive ground tractor?
Bill
01-03-2001 05:09:17
Got a friend that can,t jump start his 6 volt + ground tractor. Do you keep the jumper cables + to + and - to - ? Can you jump a 6 volt battey form a 12 volt battery? Thanks Bill
Dick L
01-03-2001 06:33:26
 Re: How do you jump start a 6 volt postive ground tractor? in reply to Bill, 01-03-2001 05:09:17
Thats the only you can do it is + to + and - to -.
I use a 12 volt jump pack and hook the - to the starter terminal and the + to the starter bolt and then push the starter rod. that way you only have 12 volts while the starter is turning.
