C Magneto switch
Fred
12-30-2000 09:43:22
What is the real purpose of the magneto switch on my C. I put on a new one when I installed the wiring harness but the tractor starts whether the switch is in or out. My uncle grew up on this tractor and does not even remember a magneto switch and said they never used it because they would just pull the throttle back all the way to kill the motor. The manual shows it , I took the old rusted one off , so there must be a purpose for it?? Thanks Fred
Duane
12-31-2000 17:20:03
 Re: C Magneto switch in reply to Fred , 12-30-2000 09:43:22
I have a 38 B and do not have a magneto kill switch. I have to shut the gas off to stop the engine. I would like to put in a kill switch but the magneto does not have a lug to connect it. Can I connect the kill switch internally in the magneto? If so where would I connect it?
Herb
12-30-2000 14:49:20
There should be a terminal on the Mag where
you hook up the switch to. the switch should
ground this terminal when pulled out.
you probably don't have a good ground in you
control box, or the switch may be bad (mine was).
