C wiring problem facts only
Fred NC
12-30-2000 09:33:50
No solution yet but here are the facts.
1)99% sure its wired correct2)99% sure ammeter is good Test results as follows from suggestions, thanks fellows: 1)With voltmeter I checked (F) post on gen casing to ground tractor not running, got no reading on DCV Scale but got a reading on ohms scale. 2) Connected both ammeter leads to + post on ammeter( to bypass ammeter) and checked voltage standing 5.5( DVC scale) and same reading with tractor running 3/4 throttle 5.5. 3)Undid the +battery cable while running and checked voltage from A to F on gen post and did not get a DCV reading also noticed at some point in this procedure the ammeter gauge needle pegged out on the discharge side and stuck.So thats where I stand. I certainly thank everyone for the thoughts and comments at least we have eliminated some possibilities. Thanks Fred Wilson,NC
