B starving for fuel
bunky
12-29-2000 18:39:56
i have a allis b it runs good sitting still high or low speeds but when you run it it stalls and starves for fuel i drained and cleaned tank and changed valve assembly any ideas
dan
12-31-2000 07:07:06
 Re: B starving for fuel in reply to bunky, 12-29-2000 18:39:56
DickL is exactly correct;probably.I recently
rebuilt a carb and cleaned and sealed the tank
on a B.what I did not take into account was all
the rust in the air cleaner assembly!Good luck
Dick L
12-29-2000 19:47:45
If your sure you have good gas flow at the carb from the tank and you have taken the bottom off the carb and cleaned the valve and seat and set the float. Take the little pipe plug out of the bottom front of the bowl, then take a small screwdriver and remove the brass jet behind the pipe plug. Blow it out good and don't try to enlarge the very small hole in the center of the brass jet. If that don't help you might check your manifold gasket, timing, points, or compression.
