Ac implements
Joshua
12-29-2000 11:12:39
anyone have any picures or diagrams of ac implements for a 54 wd , i got the 2 point but cant figure out how to make attatchments in my welding shop for it. do u use the draw bar as the third point? if so how?
Gary(Ont)
12-29-2000 15:50:12
 Re: ac implements in reply to Joshua , 12-29-2000 11:12:39
Joshua
If you go to auction web site for "www.ebay.com" then do a search on "allis manual" you should be able to locate some equipment manuals with pictures on the cover showing Allis "snap coupler and lift arm latch" setup.
Alan Farley
12-29-2000 11:32:48
The third point is a long toungue on the implement with a loop on the end of it that snaps into the "cone" or "bell" under the tractor. The implement has two chains on it with "bolts" If you will,that are fastened on each side of the arm. If you are good with a welder you can make a toungue and chains. If I had a digital camera I would send you pictures I have a toungue,chains which came off my AC planter when I welded on a 3 point. The planter was made for the WD and CA.
