Governor spring Needed or not?
Fred
12-27-2000 13:02:51
AC - C runs great without a governor spring. I have one, but someone please give me a reason to put it on??
Dick L
12-27-2000 17:04:34
 Re: Governor spring Needed or not? in reply to Fred, 12-27-2000 13:02:51
third party image
How do you have the lever in the drawing connected to the governer? The spring connects the two parts and is part of the rpm limiting system.
Fred
12-28-2000 04:41:02
 Re: Re: Governor spring Needed or not? in reply to Dick L , 12-27-2000 17:04:34
Dick, your picture shows the governor spring as a link spring and shows it upside down from my manual. Both my and your picture shows the rod from left to right when in fact on my tractor I am looking at it frome right to left??My picture shows the large loop end hooking around the top manfold bolt and the small hook around the rod. But my rod also has a small hole with a carter pin it??Do I hook the spring through this hole?Thanks Fred
Dick L
12-28-2000 04:57:05
 Re: Re: Re: Governor spring Needed or not? in reply to Fred , 12-28-2000 04:41:02
Hook the spring into the eye of the cotter key.
