No oil Pressure
Dennis
12-26-2000 18:33:20
I have a 39 "B" that builds up condensation and when cold weather comes, I have no oil pressure. In the past, I've drained the oil, cleaned the screen of debris and ice and that has done the trick. This time though, I still do not have oil pressure. Any suggestions? Can I move the tractor without damaging the engine? Help!
Dennis
LB
12-26-2000 20:59:52
 Re: No oil Pressure in reply to Dennis, 12-26-2000 18:33:20
No oil pressure sends a chill down my spine. I wouldn't run it much until you make sure it has oil pressure. Maybe there is ice in the line to the gauge, I've never heard of this but It might be possible.
Marty
12-31-2000 01:40:20
 Re: Re: No oil Pressure in reply to LB, 12-26-2000 20:59:52
I suggest if possible, tow tractor into shop, warm it up, and then prime the oil system. Do this by removing the filter, and, using a hand pump oil can and a rubber hose stuck over the filter tube, pump oil into the tube and down into the pump from above. I havent tried it myself, but I'm told it works. Good luck, let us know if it works. Marty
