Plugs foul
Don Foster
12-26-2000 16:20:33
What causes my # 3 plug to short out with carbon beteen the eletcrodes?
Phil Auten (TX)
12-27-2000 11:33:54
 Re: Plugs foul in reply to Don Foster, 12-26-2000 16:20:33
Don,
First, make sure the wires, cap and rotor are in good condition. Next, do a compression test to make sure there's not a mechanical problem. Also check the valve clearances. If all this checks out, try new plugs one or two heat ranges hotter than normal. You also might try a different brand of plug. Sometimes engines seem to favor one brand over another. It sounds like you're not working the tractor very hard. This contributes to plug fouling with the crappy gas we get nowadays.
My 2�,
Phil
c tucker
12-27-2000 18:29:24
 Re: Re: Plugs foul in reply to Phil Auten (TX), 12-27-2000 11:33:54
One thing I found that helps keep plugs clean is to make sure the engine water temp. stays above 170 degrees.If your thermostat is stuck open the engine will run too cold. ct
