Ca connecting rod shims
Larry
12-26-2000 10:33:06
Can a connecting rod require more than 4 shims as the book says,I'am using shim Part#70207523,the shims appear to be .010 each? Also does it make a difference what rod cap goes to what rod,this engine was semi assembled when I got it and only 2 caps were stamped
peterc
12-28-2000 06:01:04
 Re: ca connecting rod shims in reply to Larry, 12-26-2000 10:33:06
Measure you rod journals and take the rods and caps to a machine shop to be trued up.then you can put new bearings without shims and save yourself time and headaches.
