Ac-hand clutch
Peterc
12-24-2000 07:01:01
Helped a friend rebuild his ac engine and the tractor has a hand lever that allows it to go forward or reverse with transmission in gear. dont know what model it is but would appreciate it if someone could tell me how this set up works.diagram would also help. It is driving me nuts trying to figure it out.Thanks and Happy Holidays to all.
W.W.
12-26-2000 06:57:57
 Re: ac-hand clutch in reply to Peterc, 12-24-2000 07:01:01
my D15 has the shuttle,the lever is on the left side. 4 speed trans. forward or reverse in any gear with the lever.
PETERC
12-26-2000 07:25:22
 Re: Re: ac-hand clutch in reply to W.W., 12-26-2000 06:57:57
shuttle clutch sounds right. can anyone tell me how it works or better yet show me a picture or diagram. thanks for the help
Tom
12-24-2000 16:46:09
Are you sure it is a forward and reverse control? If it is a D-17 type of transmission it is a two speed clutch lever. There are two clutches, pushing the lever one way engages the power normally, one to one ratio. The other way engages another clutch that drives through two gear sets that gives a reduction in speed. Maybe some of the newer models had a forward and reverse lever, it would probably work the same except the "other speed" would be a reverse.
