How to make an Allis Chalmers WF go slower
David Peters
12-14-1998 10:40:18
Does anyone know of a reduction gearbox option - it is too fast for match plowing even in bottom gear!
Tim
01-29-1999 05:09:24
 Re: How to make an Allis Chalmers WF go slower in reply to David Peters, 12-14-1998 10:40:18
the way that has ben sugested to me is put a smaller tire on it . a smaller tire will still turn the same revolutions but wont cover so much ground,in effect slowing it down while keeping your rpm s up for hp. or your other option is to find someone at a transmission shop that knows enough about manual trannys to find some different gears fo it . so far finding someone that knowledgeable has been impossible for me. great luck!!!and remember if you wanted a tractor that doesnt move get a john deere !!lol
Ted Buisker
12-17-1998 05:17:19
What will help, would be an RC ring and pinion. The RC was geared lower than the WC which shares a driveline with the WF, but good luck finding one. Hope this helps. And don't worry about those guys comments that bleed green, heck it was almost 1960 before they could get a JD to run on more than two cylinders. TED
John
12-16-1998 20:04:39
The last time I plowed (JD 4630) we plowed at 6 mph. How slow would you want to go?? Speed throws the dirt to smoothe the field. Less disking.
You could always pull the throttle back and run at less engine speed.
Keith
12-15-1998 19:06:58
you could just sell it to me, and you'd never ever have a problem again!
egor
12-15-1998 18:04:57
I didnt know they would pull a plow. GREEN all the way
russ
09-28-1999 13:48:56
 Re: Re: How to make an Allis Chalmers WF go slower in reply to egor , 12-15-1998 18:04:57
old trick we used to use on cars
put two transmissions in line {series}
if you have the room
