WD-45 6-Cylinder Gas?
Stan
12-15-2000 12:59:39
Was there a factory-built WD-45 with a 6-cylinder gasoline engine? I've seen one but I wonder if it was stock?
Thanks,
Stan
LHud
12-17-2000 19:28:07
 Re: WD-45 6-Cylinder Gas? in reply to Stan, 12-15-2000 12:59:39
The 45 only had a diesel in it.The gas engine was put in the A Gleaner combine. Many people replaced the diesel with the gas after the engine went down. It was a matter of economics. The gas engine was a lot cheaper. I have a 45-D with the 230 gas in it. I bought it that way. I use it to feed with in the winter time. It will crank any time. A gas engine turned by a diesel starter and two 6 volt batteries.I don't know who did the conversion on my tractor but it works very well. LHud
Randy
12-17-2000 16:40:38
The WD-45 was a 6 cylinder Buda diesel only. The block of the buda was the same in the diesel or the gas, even the 230ci or the 262ci. So a gas head would bolt on a diesel block even with the higher compression piston and run good. A plug was put in the diesel block where the distributor goes and the governor went where diesel pump went. The only difference between the 262 and the 230 was a longer stroke crankshaft.
Dave Bowers
12-16-2000 06:47:50
It's a buda 230 maybe from an AC combine. There was one at Ankani and he called it a WD 55. Dave and Mary Bowers
Darrell (MN)
12-15-2000 16:58:33
Stan, it was probably a diesel but someone has put a gas engine in it to replace the diesel when it went bad.
Stan
12-16-2000 03:44:38
 Re: Re: WD-45 6-Cylinder Gas? in reply to Darrell (MN), 12-15-2000 16:58:33
Would that have been a Buda gasoline engine?
Thanks,
Stan
Phil Auten (TX)
12-15-2000 14:27:01
Stan,
The only 6 cylinder WD-45's were the diesels.
Phil
