Installing sleeves
Bill
12-13-2000 17:56:02
Assembling WD engine. On installing the piston sleeves the I&T manual says use palm oil or vaseline on the neoprene sealing rings. Engine rebuilder says use STP. I'd appreciate your comments or suggestions on what works best.
Thanks Bill
Doug H
12-17-2000 16:49:56
 Re: installing sleeves in reply to Bill, 12-13-2000 17:56:02
Yes when you have it clean do it again. I have used tincture green soap for 35 years with no problem. Doug
Aaron
12-14-2000 15:33:50
Do NOT use vasoline. I fought for 2 hours to get ONE sleeve in with that worthless stuff on the thing. After consulting a local AC guru, I switched to simple cooking oil. Mazola, I think it was. Just a VERY thin coat on the o-rings and they dropped right in, all 4 in less than 10 minutes. Just had to push a little to get them seated. Much, much better than the heavy stuff. Stick with lighter oils.
Aaron
Dick L
12-13-2000 19:02:53
None of your choices will attact the neoprene and that is what counts. I have also used liqud dish soap. Just make sure that you dont pinch or scuff an O ring. Make sure that the bare sleeve will slide all the way down and turn freely by hand before installing the O rings. You will then be able to feel the O ring as it slides by. It takes extra force to pinch and slice off some of the O ring.
motrack
12-13-2000 19:25:40
 Re: Re: installing sleeves in reply to Dick L, 12-13-2000 19:02:53
I second what Dick said..... .
Brian G.
12-15-2000 07:06:08
 Re: Re: Re: installing sleeves in reply to motrack, 12-13-2000 19:25:40
Has anybody tried brake assembly lube? It's a real thick silicon like liquid and I use it for a lot of things it wasn't intended for. It's a little like my cotter pin puller. I use it all the time but I've never pulled a cotter pin with it.
