AC-C hydraulic leak
ZIM
12-12-2000 12:29:35
My rear little hydraulic cylinder on my C is leaking from the ram shaft. It only leaks wnen in use. how do I fix this, where do I get the parts, or do I buy a new one and what would that set me back. Any help would be appreciated. Thanks
Tyler(WA)
12-13-2000 05:58:50
 Re: AC-C hydraulic leak in reply to ZIM, 12-12-2000 12:29:35
Good advice here. These cylinders are not hard to work on. Basically, you have a shaft on a "hockey puck" looking plug with "O" rings to seal against the cylider walls. Then you have a front cylinder plug with a hole in it to let the shaft poke out. That's the "gland." Everything is pretty straight forward and simple to work with. Keep things clean in your work area and don't get the idea that this takes any kind of expert to repair.
I've rebuilt three so far and they're all working fine. At several hundred dollars replacement cost for a new cylinder, $12 worth of new seals sure looks attractive.
Sandy Lake Implement
12-12-2000 19:18:37
Try tighteneing the gland nut on the end of the
ram. It was designed to crush the packing and
should be able to be snugged several times before
it bottoms out. If you need new packing we have
it on stock. Remove the nut & work the old stack
out,slide the new stack into place, reinstall
& snug the nut.
T. Seifert
12-12-2000 18:07:59
Take the cyclendar to your AGCo Ac dealer and buy new packing. There was more than one type of cyclindar used.
Ted
