: I have some ALLIS B hydraulic parts for sale. I have been restoring ALLIS tractors for years, and have some parts avaiable for purchase. Robert, Am replying to your post in Yesterdays Tractor. I have a 1949 Allis C that I am working on. I've returned from the barn a couple of hours ago and just posted this message to the Stratton Allis Page: "I replaced my trans/hydralic oil with 7 qts of 20 wt oil. I believe what was in it was heavier, which may have been the reason why the pump was not working. When I engaged the pto and tried the hydralics they worked. But oil came out of the end of the cylinder and the housing is cracked and oil comes out of it. I have just taken the pump off. I am hoping that it can be braized or maybe even JD Weld. Here are my questions. 1. What about the cylinder leaking? 2. Is my idea of braizing the pump feasible? 3. How does the pump operate. When I pull on the lever, the cylinder goes out. And when I release it, is it suppose to go back in by the weight of the implement. The hydralics on my Farmall Cub, push lever up and hydralics go one way, push it down it goes the other. Any and all suggestions are appreciated. Thanks for the past posting help. Had purchased Detergent Oil and then got the post before I put it in. Thanks again. [email protected]." Can you help. Also, is it possible to replace the casing w/o replacing the whole pump. After we get out daughter to bed, will probably go out and look at the pump more closely. Thanks Tim Nobles South Dayton, NY
