Bars Leak
Murphy
12-08-2000 08:38:56
Allis' nose is still running. I remember when I had my '67 Mustang it developed a small leak in the radiator and someone told me to put in some Bars Leak. I sold the car some 10 years later without ever seeing that leak again. Would that work on an old Allis? Does anyone know how that stuff works and what kind of residue I'll end up with in my block, pump and radiator?
Dick L
12-08-2000 10:56:11
 Re: Bars Leak in reply to Murphy, 12-08-2000 08:38:56
Sorry but I have a bad memory. Are you the one that had a small drip from the water pump? If this is where the drip is from, Barrs Leak wont help. I use stop leak compounds in my pulling tractors to keep water out of the oil pan.
Murphy
12-09-2000 18:05:42
 Re: Re: Bars Leak in reply to Dick L, 12-08-2000 10:56:11
D.L. your memory is as sharp as ever! (I won't hazard a guess as to how sharp it was to begin with)... but yup that was me. The leak is apparently starting aroung the pump shaft.
Nuts, Mrs. Murphy just caught me on here. gotta go!
Tyler(WA)
12-08-2000 10:11:20
Any of the temporary radiator leak sealants are just that.... temporary.
They're meant to be a short term fix to get you home or limp an old car along until you sell it or can get to a more lasting repair.
I know many stories (some of my own) where Aluma-seal or some other brand, has lasted a LONG time but it's still a temporary patch.
This is your tractor and I would guess you plan to keep it awhile. Why not take the radiator off and have a radiator shop check the core and tank? I've had small core leaks repaired for only $10 or so. If your core is bad, your engine isn't getting the cooling it needs and you might be saving yourself some costly repairs by replacing the core now.
Temporary sealants also pass through your engine and collect in the block. I've seen noticable piles of the stuff, when rebuilding engines, and always boil the block when I see it.
I'd put Bars-Leak or Aluma-Seal in an old car in a minute but would never put it in one of my tractors. IMHO of course.
LazyHorse
12-08-2000 08:49:09
You can try it. I like aluma-seal better.
