Best method to get rust out of a gas tank?
Fred
12-04-2000 14:37:01
Anyone know the best way to get a small amount of rust out of a gas tank on a C?
Darrell(MN)
12-06-2000 16:19:31
 Re: Best method to get rust out of a gas tank? in reply to Fred, 12-04-2000 14:37:01
Fred, Thats an awfull lot of responses for such a small amount of rust...lol...and it just shows how inovative some people can be. There is a lot of pretty good ideas there, I'm going to write some of these down for future reference. Darrell(MN)
Gordon in IN
12-06-2000 07:25:54
Drain tank, remove valve and filter assembly, plug the valve hole with a pipe plug, remove tank from tractor, put 10 lbs of small gravel or crushed stone in tank, add three pounds of sand, some "automatic dish washing detergent" and very warm (not too hot) water to get a "slushy" mix. Put the cap on the tank, place the tank on a BASKETBALL and roll the tank around on the top of the basketball for a while. You keep the "slushy mix" in the tank on top of the basketball while rolling the tank from side to side and back and forth. At the same time you tip the tank to keep the "slushy mix" over the basket ball. Concentrate your efforts so that the "slushy mix" works on the rustiest areas most. Work the entire inside of the tank in this way. Should take about twenty minutes. This sounds difficult and is a lot harder to explain than it is to do once you get the feel of it. After you do one you will think it is easy. Dump out the mix, flush with clean warm or hot water and dry and oil the inside of the tank. When you put the tractor away for the winter or to not be used for a while add a little "chain saw" gas mix to the tank to prevent rusting. Hope this helps, Gordon in IN
Butch(OH)
12-05-2000 05:42:16
Eastwood Co. has a kit that has all of the stuff you need to clean and coat the tank for about $35. You have to purchase the acid and solvent locally and you will spend close to $45 total. Be carefull with the acid if you go that route!!
Doug
12-04-2000 19:20:36
Watkins Toilet Bowl Cleaner! You get it from your neighborhood Watkins dealer. Pour it in, roll the tank around, wait a few minutes and pour it out, (save it, as it will still be good for cleaning something else) then put your water hose in the filler hole and flush. Then go to your auto parts store and get a can of gas tank coating. It will put a nice plastic coating on the inside of your gas tank. Works great!!
Mike
12-04-2000 17:05:58
I took the tank off and put a piece of small chain
in it with some mineral sprits. Then shake it like
a milk shake and rinse. Worked well for me.
Dick L
12-04-2000 15:00:38
I am not sure what is the best way, but a sure way is to take it to a radiator shop and have it boiled out in there acid tank and sealed or coated on the inside. They will weld up any pin holes and repair the thin spots. Can cost from 80.00 up. If you don't have the 80 bucks I guess it would not be the best way.
steam
12-04-2000 14:38:14
Steam Cleaner
c tucker
12-04-2000 15:48:48
 Re: Re: Best method to get rust out of a gas tank? in reply to steam , 12-04-2000 14:38:14
I think Dick has the right idea. I have used mauratic(sp?) acid available at lumber yards etc.
You have to rinse the tank out with water after cleaning with the acid. c tucker
tommyw
12-04-2000 20:07:45
 Re: Re: Re: Best method to get rust out of a gas tank? in reply to c tucker, 12-04-2000 15:48:48
ive had them put in the acid tank at the rad. shop this works well. the guy that owns the shop is a high school friend so he doesent charge me, that is the best way ive found
John T.
12-05-2000 06:42:03
 Re: Re: Re: Re: Best method to get rust out of a gas tank? in reply to tommyw, 12-04-2000 20:07:45
I do a lot of gas tanks and the best way I have found is to jack a tractor up on one side,lock the other side brake,strap the tank to the wheel that is off the ground,put about two cups of 1/2 inch rocks in the tank and run the tractor for about 1/2 hour.I tried running it with chain in the tank,took seven hours to get the chain out of the tank. John T.
Alvin
12-05-2000 17:28:33
 Re: Re: Re: Re: Re: Best method to get rust out of a gas tank? in reply to John T., 12-05-2000 06:42:03
Gads! How long was the chain? or did somebody tie a bunch of knots in it ?
