Model B rims from Miller
Butch (OH)
12-04-2000 10:36:05
Has anyone used the model B repro rear rims from Miller Tire? Curious if the quality and fit is OK.
Ted
12-28-2000 15:16:29
 Re: Model B rims from Miller in reply to Butch (OH), 12-04-2000 10:36:05
Unless your trying to keep the B as it was from new, Farmall A rims will fit on your B. Farmall A rims are available from several places, including the CT Farm & Country stores. The Farmall A rim has four loops welded on the rim where they attach. The loop holes line up with the AC B Model hub holes. Hope this of some help to you.
wu
10-01-2003 21:38:05
 Re: Re: Model B rims from Miller in reply to Ted, 12-28-2000 15:16:29
I've heard about trouble with old style (bevel) rims. Apparently the bolts and clamps work themselves loose. Is this true? Which rims are the better choice?
Mike (Oh)
12-06-2000 08:15:54
I Dont know how the newer B's rims bolted on (did they go to the 4 bolt loop ?) but when I had to replace the wedge type rims on my 38 B I went to the 4 loop style. What I ran into was the cast wheel was too big and the bolt holes were 3/4 on the cast wheel and the largest that would fit through the loop was 5/8 (or 7/8 and 3/4 something like that). I found a newer parts C that the cast wheels were a bit smaller around and had the smaller bolt holes that the 4 loop rims fit on perfectly. My point is there seems to be 2 sizes of the cast wheels around. Dont get surprised like I did.
Thomas
12-04-2000 18:08:46
Butch I used two rims 4 lop type from miller on my
B. The quailty was very good. Only thing they are not like the orginal.They fasten with four better
grade bolts.
Butch(OH)
12-05-2000 04:44:31
 Re: Re: Model B rims from Miller in reply to Thomas, 12-04-2000 18:08:46
Miller is now supposed to have repro rims that use the original lugs instead of the four loop replacements. Norm, what are you asking for the used set?
