D 17 Wide Front
Scott Mills
12-03-2000 18:39:27
Is there a difference between a wide front for a diesel or gas model? What all do I need to convert from a norrow to a wide?
Collin
12-04-2000 07:35:10
 Re: D 17 Wide Front in reply to Scott Mills, 12-03-2000 18:39:27
A diesel has a longer A mount than a gas tractor. However by turning the pivot mount bolt around and adding a spacer with a hardened 5/8 bolt, it will work. I have a wide front end off of a diesel on my gas tractor and it works fine.
D-17 Dave
12-03-2000 19:47:01
Easy swap. Most any salvage yard you talk to will be familiar with these parts. Just make shure you get the pivot mount that mounts to the bell housing. You will probably have to drill and tap these holes for mounting, I did. also when you unbolt the narrow pedistal from the rad. support you will need the arm that the tie rods bolt to befor mounting the main front pivot casting. Agood idea will be to go get new adjustable tie rods while you are changeing this to keep the front as tight as posible.I got mine from AGCO cheaper than any where else I could find at the time and of course they were a perfect fit. I assume you have power steering already, If not this is the perfect time to add as you will already have half of it off. Dave
