About WD/WD45 pistons
Bill
12-01-2000 18:43:15
I have a WD that needs pistons and I have a good set of WD45 pistons and sleeves. Can I use WD45 pistons and sleeves in a WD engine successfully? Does it change the compression?
Bruce Nelson
12-02-2000 04:35:02
 Re: about WD/WD45 pistons in reply to Bill, 12-01-2000 18:43:15
WD45 sleeves & pistons will fit right into your WD block. You will lose compression as the WD45 has 1/2" longer stroke & the pistons have less compression height because of this. A tractor like this will run fine, but will be short on power.
