Snowblower for a Allis model CA
Don
12-01-2000 16:38:05
Where can I find a two stage snowblower that attaches to the front of my CA tractor and uses the PTO?
I have found a person that has a model 320 snowblower that is 5 feet wide and was mounted on an International lo-boy 185 with ~91 inch drive shaft connected to the PTO. Could something like this be modified to work?
Tom
12-01-2000 17:02:55
 Re: Snowblower for a Allis model CA in reply to Don, 12-01-2000 16:38:05
The pto on a cub/cub lowboy runs at engine speed, about 1800 rpm, not the 540 of the more standard pto. Something to think about in whether or not you can use this snowblower.
Glenn
12-02-2000 19:58:41
 Re: Re: Snowblower for a Allis model CA in reply to Tom, 12-01-2000 17:02:55
The PTO on a Cub also turns in the opposite direction of a conventional PTO. I've seen an adapter that slides on the end of a Cub PTO shaft that changes the direction of the PTO and is geared to change shaft speed to 540 RPM. I'm not sure who makes it, though.
