WD HydraulicPumpKnockWhenCold
PetoskeyDave
12-01-2000 05:35:14
I hear a knock when I lift my 3 point shortly after starting. Am I doing damage?
Aaron
12-01-2000 15:37:07
 Re: WD HydraulicPumpKnockWhenCold in reply to PetoskeyDave, 12-01-2000 05:35:14
Are you returning the lever to the neutral position when you get it up? If not, it'll sit there and pump pressure. That'll make it knock.
Aaron
PetoskeyDave
12-02-2000 03:18:44
 Re: Re: WD HydraulicPumpKnockWhenCold in reply to Aaron, 12-01-2000 15:37:07
Thanks for your response. Yes, it starts to knock as soon as it begins to lift. This the second rebuilt pump. I thought the first one failed because my snowblower was heavy. I put on larger lift cylinders. It knocks even on a light implement. I'm using 10 weight hydraulic oil. The cam lobs wore the first time and I don't want to replace that shaft again. I was hoping I would hear that this sound is normal. Maybe not, eh?
