Spindles for a B
Craig
11-30-2000 07:34:09
Any ideas on where one might find spindles and spindle bushings for an Allis model B? The local dealer said that the spindles were no longer available, but he could get the bushings. Factory bushings at that factory price.
Thanks
Charles Jackson
12-02-2000 08:32:52
 Re: Spindles for a B in reply to Craig, 11-30-2000 07:34:09
I sell bushing that are slightly longer than A/C
original for $25 per set of 4 plus shipping.
Thomas
11-30-2000 17:38:45
I had spindles built up and turn at michine shop
for a CA.Also steering arms rework.They fitted and work very well.
I recomend new bushing, most likely if spindle are worn the bushing are goners.
Tom
11-30-2000 16:29:41
I don't know what the bushings look like, haven't had them out, you might take mesurements to a bearing supply house and see if they have a stock bronze bushing that will work. As a last resort, spindles could be welded and turned down to size. There are processes that spray metal onto the part, probably expensive. I an not familiar with the process or price though.
Tom
11-30-2000 16:29:06
Ted
11-30-2000 18:17:48
 Re: Re: Spindles for a B in reply to Tom, 11-30-2000 16:29:06
Bushings are available from AGCO-Allis $6-8. Does anyone know of a machine shop that has spray weld spindles for a reasonable price. I found a shop that will do it for $75 each when he gets time That was two months ago and no promise date in site. He really does not want to do it. I have 4 spindles to be done.
Rick in NC
12-01-2000 12:18:21
 Re: Re: Re: Spindles for a B in reply to Ted, 11-30-2000 18:17:48
I was fortunate enough to find a machinist in Wade, NC, that welded up, turned down, polished, and cold blued the spindle pins for $100 for both. My bushings were not worn out. The spindle pins had not been lubed properly over the years and were worn. New bushings had been installed in the past but did not and could not cure the problem. All four bushings were bought from the AGCO dealer for $6 each.
