Need some help with my wd45 hydrolics
Dave
11-29-2000 14:54:43
Just purchased a wd45. The hydrolics don't work and I am not familiar with this tractor. Where should I start to look?
c tucker
11-30-2000 17:57:40
 Re: Need some help with my wd45 hydrolics in reply to Dave, 11-29-2000 14:54:43
I had a similar problem wiith my 45 last summer.
After disassembling the pump I found the shoulder on the relief spool broken off. This caused the pump to by-pass all the time.I had a guy a little more familiar with these things rebuild the pump but the new spool(purchased from an AGCO dealer)wasn't machine right.A 1/4 inch deep flat bottomed hole in the center of the spool was omitted,causing way too much pressure. I blew out a 5000 psi gage.The pump bypassed at 9250psi.After another tear down,some machine work,and reassembly I have 3000 psi.I'm just real thankful the tractor and I are still in one piece. c tucker
David Thomas
11-30-2000 12:30:16
The hydraulic pump is located in the right side of the tractor just behind the side PTO.
The pump can be set for all sorts of jobs so be sure that it is set up correctly for the job you need to do. There should be a decal on the battery box just above the pump that shows you how to set the pump up. The pump has four manual adjustment knobs. The most commonly used set up for me is the hold positon setting. The lowest knob on the side of the pump is the drawbar adjustment. Its use is for pulling plows and the like and give traction control. Turn this knob all the way into the body locking the plate into position. The second knob is on top of the pump on the side linkages. This is the hold position adjustment. Turn it so that it locks the two plates together, allowing them to move as one. The third knob is also on top but on the front of the pump. This controls the delay lift. Turn it all the way out until it hits its stop. The last knob is on the front of the pump about half way down. It controls the rate of lift. Turning it all the way out gives you fast lift. All the way in is slow lift.
If you are having the same problems I had, the pump isn't developing the pressure it should before the unloading valve pops off (also called a pressure relief valve). It worked fine without a load but could not lift anything heavy.
I first bought a pressure gauge (0-5000 psi) and installed it at the small port on the top front of the pump where the 'booster gauge' was normally attached. My pump was only developing about 1000 psi, less than a third of its 3500 psi rating and that wasn't enough to pickup even a 4x4 round bale of hay.
You'll have to pull the pump off the tractor (three nuts and two bolts) to access the front cover plate. Four bolts takes the plate off. The plate covers two cylinders, the first one has a the last manual adjustment knob I mentioned above, the rate of lift control. The cylinder without the adjustment contains the unloading valve. Pull the piston out of the cylinder. This is the valve seat assembly which has two o-rings outside and contains the valve seat internally. Watch out for the valve ball as it may pop or fall out unexpectedly. Next pull out the upper spring retainer. Watch out for shims falling off the underside of this retainer. Last out is the spring itself. The spring may be broken or may have weakened over the years, or the o-rings around the valve seat assembly may be leaking.
Adjustments are made by adding more shims on top of the spring to increase the working pressure. (if you put shims under the spring, be sure they don't block the off-center hole in the lower spring retainer.) Its trial and error here. I doubled the number of shims (a little over a sixteenth of an inch) and still need to reinstall the pump to see where this brings me. If it isn't enough, I'll have to pull the pump off the tractor again and add more shims. If its over 3500 psi by my gauge, I'll either have to pull some shims out or be very carefull not to hit the end of travel on the rams and blow hoses (at best).
Of course your problem may be something else entirely, so get that pressure gauge installed as a first step. Mine was fairly cheap at $20.
